Bridges w/ 1/8" slot
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=8308
Author:  Matthew Bryan [ Mon Sep 04, 2006 8:34 am ]
Hello all,
I was wondering who sells pinned acoustic guitar bridges with a 1/8" saddle slot already routed? I have found plenty ready made bridges with 3/32" slots but not any 1/8".
Thanks for any info!
Author:  A Peebels [ Mon Sep 04, 2006 9:11 am ]
I cut my own. I made a fixture to hold the blank at the proper angle. I hold the blank in place with doubleside carpet tape from the BORG. I then use an edge guide on my laminate trimmer to make the cut. I usually cut the slot in 3 passes. I should use end stops, but I usually just make dots with a silver felt tip to indicate the ends of the cut. The same fixture could be used to widen existing slots if you do not want to carve your own bridge. I use a downcut bit because it makes a smooth cut, but it packs chips in the bottom of the slot. Between passes I dig out the chips with a dental pick.
Author:  tippie53 [ Mon Sep 04, 2006 10:45 am ]
Blues creek has 1/8 slot bridges. What style and spacing ?
$20 delivered in the US
john
Author:  bob J [ Tue Sep 05, 2006 12:46 am ]
The BORG!?
'Captain, I can't hold'er!'
